주요 콘텐츠로 건너뛰기
The MSI GE72 6QF Apache Pro is a Windows 10 , 17.3in, quad-core 2.6GHz Intel Core i7-6700HQ, gaming laptop which was released in 2016.
Headphone Jack Weird After Physical Damage
I recently tripped over my earbuds when walking away from my computer and ripped them out of the headphone jack. This caused the metal piece at the front to break off and fly across the room. I found it and it seems like it wasn't attached to any wires or connections. Now when I plug in my earbuds it doesn't detect them normally. It plays audio through both my earbuds and my computer unless I mute my audio. When I mute my audio it plays only through my earbuds. I guess I can deal with this, but I'm wondering if there's a quick fix, and if not if there is a way I can make sure it doesn't get damaged further.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
I had the same problem. I soldered it again. But the sound comes from the headphone, not the speaker. What can I do, can you help me? My e-mail is y.akifender@gmail.com. You can send an e-mail to this e-mail. Thank you very much in advance for your help.
댓글 달기
답변 1개
The audio jack has 3 rounded pins inside the female connector. 3 also lead in from the rear of the input.
This lets the chip turns the audio build in speakers or jack on and off.
Like myself. You are going to have to open it up. Inspect the audio jack. Come the the conclusion the jack
numeric value is near impossible to read and hunt for a replacement. This is going to require a complete
disassembly of the laptop and motherboard/pcb components from the case, and if your not confidant
you can restore it… Take it to a shop that deals with electronics. New jack. Solder, Wick, Solder iron is
required. + a precision screwdriver of the + variant.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ethan Wilson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 274
