주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
779 질문 전체 보기
How do I get out something that is stuck inside the headphones jack?
Hi everyone,
One on the screws the hold up the lower case must have gotten loose and it lodged itself in the headphones jack while I put my laptop in it's protective bag.
I can't get the screw to come out and I can't connect my headphones since the screw is blocking the jack.
On top of this, the screw itself seems to be shorting something inside the jack, because the system seems to be acting as though something is connected to the jack because I now have some problems with the control of the sound volume.
Ideas?
Thanks,
Uri
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
The only thing I can recommend is a pair of dental picks and a good magnifier to hopefully snag it. Once its loose shake it out. Banging the connector edge on a rubber pad may also loosen it. Just don't be to ruff
Be careful you don't push it in deeper.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Uri Shilo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 45
