주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
Why is my home button repeatedly tapping?
I have been noticing when I charge my phone through an extension cable my home button repeatedly taps. I can hold the home button and it will tap by itself over 10 times per second really fast like that and It is annoying because when I want to go back to the home screen from an app I have to go in the tabs screen (the screen that appears when you double tap the home button) and select my home screen manually.
I have not found a solution for this topic online and I have not even found anyone with this issue online so if you could help that would help me out a lot.
Thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 5개
선택된 답변
Other than trying a different charge cable, there's not much any independent repair shop can do to repair the Home Button on the iPhone 7. Your best bet is to go to the Apple Store and have them take a look.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Minho is right but apple is just going to try to sell the product. 3rd party Repair store could do a full diagnostic on your phone and tell you what's wrong but yes only apple can replace the home button
댓글 달기
5/1/2019, mine is actually doing that too. Has been doing it about once every few months or so recently. I just turn it off and turn it back on again and it stops it from multi-clicking.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If its only doing it when ur using a certain charger then try replacing the charger… I have had and chargers cause screen issues before when plugged in have had it happen if their not giving the right amount of power as in too little power for the phone… and that sounds about right if ur using a longer cable, or damaged cable or dodgy plug … usually the standard length cable is that length for a reason :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Either U10 IC on the home button or the cable to the U10 IC was broken. Both case is fixable.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
im having the same problem with my iphone se. anytime i plug it into a surge protector or extension cable it clicks multiple times. however, when i plug it into a wall outlet right after i plug it into an extention cord it still clicks multiple times.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Alexander Rakita 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 26
전체 시간: 16,533
