iPad Air won’t charge/stays at 3% after digitizer replacement
Hi!
Yesterday I replaced a busted digitizer on my iPad Air. Checked to see if everything was working properly before seating the digitizer, except for seeing if it charged properly.
So I plugged it in to the correct charger and have had no luck getting it to charge properly. It’s been plugged in for 10 hours and the highest it got was 5%, dropping back to 2% within 5 minutes, then cutting off very shortly after.
I’ve read very limited posts referring to a filter on the battery that acts as a ‘gas gauge’ if you will. FL7500 or some sort. Regardless, I’m failing to find any how-to or work-around for this issue and I need to get this resolved ASAP as I use this iPad for work constantly.
Any help would be greatly appreciated!
좋은 질문 입니까?
