MacBook Pro 15" display 모델
6588 질문 전체 보기
Why are my fans running to fast?
My fans are always running at high speed. SMC Reset doesn't work. smcFanControl works, but the default speed is over 5000 rpm. Sometimes, fans make a wierd sound, and smcFanControl says its about 200 rpm. Also, smcFanControl only has left fan setting.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Is your processor temp normal?
의 답변
Please report your temp BEFORE you "teardown"...
Sometimes SMC will glitch... very common and no need for teardown.
의 답변
The OP stated he reset the SMC.
의 답변
Serial # is ********7XJ for mayer.
의 답변
i don't know what is the normal temperature for processor it ranges from 130 to 170. i dont do tasks that require a lot of processor power like movies.
의 답변
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
Sounds like it's time to open it up blow the fans out, remove the logic board and clean the heat sink intakes, and replace the thermal paste. There are five machines in the A1286 line, please give the last three letters of your serial number so I can positively identify your exact machine and direct you to the correct teardown. That number is located in your battery compartment. Thanks
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
Ben Iofel 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,442
