Broke the lightning connector - parts stuck in logicboard
Hi.
My phone won't charge. I replaced the battery and the phone lasted for some time (20% remaining on new battery). Then I bought a new dock connector to try. The problem is that when I disconnected this, half of it got stuck in the connector.
Is this repairable? I have not been able to pull the parts out with my 0,8mm flat screwdriver.
Any advice and help is much appreciated!
Se link for pictures of the contact.
Thank you
좋은 질문 입니까?
댓글 3개
try a set of fine point tweezers
daniel 의
Bought some tweezers. Didn't help and I guess it's getting more and more damaged now...
Will this repair be comparable that of the Tristar replacement then? Maybe a repair shop that does microsoldering can do them both(?)
Thank you for your reply, daniel.
Bjørnar 의
you will just need someone that can microsolder to remove the old connector and solder on a new 1
daniel 의
