주요 콘텐츠로 건너뛰기
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
213 질문 전체 보기
How do I get my iPad to charge?
My iPad doesn't charge. It's never had a problem like this before. What happens is when I charge it, it will turn on at 2% and then die a few seconds later. What's wrong with it and how can I fix the problem?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
@meg753 check to make sure that your cable is okay and try a different charger or verify that the charger works properly by charging a different device. If so check the lightning port and make sure that there is no debris etc. in it. After that you do want to consider a new battery. Not an easy task but it is doable, just follow this guide iPad Air 2 Wi-Fi Battery Replacement
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks for the feedback. I've already tried using the charger on another device as well as checking the port for debris. I'm a little disappointed that I'll have to change the battery, but like you said, it's doable. However, the manual you attached will be very helpful. Thanks!
댓글 달기
귀하의 답변을 추가하세요
Megan :) 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 316
