주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for the first generation Nissan Murano, from the 2003 model year to 2007.
My 2005 Nissan Murano is not accelerating over 60mph on the highway?
Hello there, so I had an issue initially with my throttle body, got it replaced. After replacing it, I keep getting a code about idle re-learn. I did the procedure correctly to set off the engine code. Now my 2005 Nissan Murano is not allowing me to go past 60mph when I get on the highway. After replacing the throttle body and re-learning the idle, my cars acceleration isn't up to par and I can't figure out what it is that's preventing me from getting this fixed. Appreciate everyone that reads this, any feedback would be helpful. Thank you
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Had similar problem, had rpm but not much speed. Would take longer time to get up to speed( 60 mph). Found that the cvt ( tranny) was bad, new tranny problem fixed. Also check voltage, bad alternator , low voltage, than you get no rpm when stepping on peddle, also could be battery with low voltage( bad or shorted cell) The cvt is excellerate by wire( voltage), no or low voltage , no speed. Hope this helps
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
David Mendoza 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 30
전체 시간: 4,516
