주요 콘텐츠로 건너뛰기
The OontZ Angle 3 is a high quality, lightweight speaker made by Cambridge SoundWorks.
Why won't the Oontz Angle 3 speaker connect with PC Bluetooth?
The connection worked previously, I have no idea what has changed.
The PC sees the speaker, but the speaker doesn't play.
I tested the PC with AUX cable which works, I am also able to connect the speaker through Bluetooth on my phone.
I have checked all my PC settings and have no idea what else to look.
Help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
This happened to me, too, recently. Just after updating my PC, the Oontz Angle 3 would only be recognized as "Bluetooth Headset" and would fail to connect.
I have obviously removed the Oontz Angle Device 3 and tried to reconnect it.
I have also deleted/reinstalled any/all Bluetooth drivers on my computer.
The Oontz connects perfectly well on my iPhone, however.
What is going on?
I still don't know the reason, but it worked for me when I uninstaled the speaker and installed it again. It happened to me a few times the Bluetooth connection didn't work without this "manual reset". So, go to devices, installations, and remove and then again add the speaker. I hope this helps you too!
댓글 달기
답변 1개
In my case, the computer was able to identify the speaker but it would not connect, giving a message that the device was not responding. After trying a number of other possible fixes, such as deleting it from the computer memory, rebooting the computer, turning off the firewall, I turned off the speaker and even disconnected it from the USB cable. I let it sit, powered down, for about 3 minutes, and then restarted the process. It connected without a problem.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kristina Bogataj 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 3,566
