Please remember to ensure all connections are snug, and you do a hard reset after each replacement.
if you have tried 5 flexes from a trusted supplier, then i would follow the steps below.
1) Try replacing the other camera: the circuits in iphone cameras are linked, and sometimes, a small discrepency in the other camera can be the cause of a fault in the one you are struggling with.
2) Damaged or missing components: Using a microscope for this helps. scan the board for missing components, or scratches and chips out of ICs, and coils.
3) Reflow the FPC Connector on the board: Make sure there are no damaged pins, and reflow the connector to ensure connection to the board.
4) use a multimeter to check for continuity of the coils (Resisters, inductors, caps, etc) around the connector for your camera flex, and replace any that are not getting a full circuit.
