주요 콘텐츠로 건너뛰기
모델 A1369, 1.6, 1.7, or 1.8 GHz 프로세서, 64, 128 또는 256GB 플래시 저장공간
328 질문 전체 보기
What WiFi bluetooth card to upgrade my 2011 MacBook Air?
What WiFi bluetooth card to upgrade my mid-2011 macBook Air? wifi card to be able to connect to 802.11 AC? My hopes are to enable Apple Watch unlock along with continuity and handoff under High Sierra. Anyone try this would this work? Are the antenna wire long enough to reach the new card? Are extensions available if not?
Would this be the correct part# BCM94360CS2?
Thanks for the help guys.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
Yes, it will work. Make sure you get a dual-band card and purchase extensions just in case. Below is a replacement guide.
MacBook Air 13" Mid 2011 AirPort/Bluetooth Card Replacement
Update (11/28/2017)
That is indeed the correct part number, no extensions should be needed. Look in the guide I posted earlier to help you replace/reassemble your laptop after completing the replacement. Good luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
Thanks, That card is a different number and looks different is that the 2012 card? I think I need a mid-2013 or newer card to use Apple Watch unlock feature. Which is why I was looking at BCM94360CS2. Also, . where do I find the extensions?
I updated the answer.
Thanks, much appreciated
I don't see a link to the extension cables you mentioned in your comment or the guide. I know I found a set last week, but I can't find it now. Can you help me out with finding them or what I should be searching for, please? thanks!
This did not work for me, the BCM94360CS2 is a longer card than the original, there was no way to secure it once installed.
댓글 달기
Hey Jorge,
Did you do this yet?
I'm waiting for my BCM94360CS2 to come in the post.
I believe one of the antennas will be too short. you'll have to reroute it.
Regards,
Stephan
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Has anyone been able to get this to work? quicker tech is so dissapointing .
댓글 달기
귀하의 답변을 추가하세요
Jorge 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 28
전체 시간: 2,819
