2006 중반기/ 모델 번호 A1181 / 검정 또는 흰색 케이스 / 1.83 or 2.0 GHz Intel Core Duo 프로세서.
516 질문 전체 보기
Logic board upgrade. Will it fit?
Hi,
I recently changed the battery connector and the DC-IN of my Macbook but the battery still won't charge (The AC charger and the battery are in working order). So I guess the logic board needs to be replaced.
While I'm at it I wanted to upgrade to a early 2008 logic board:
http://cgi.ebay.nl/ws/eBayISAPI.dll?View...
I noticed on the Hi-res pics:
http://67.19.154.220/HQ/apple_macbook_13...
that some of the connectors are different. Like the heatsink connectors. Other than that I did not see a difference compared to my current logic board.
Anyway, my question is: Will it fit? And what else will I need to replace besides the heatsink?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
Try running Coconut battery to see if you can get a better idea of what's going on. http://www.coconut-flavour.com/coconutba...
Please list the last three letters of your serial number so that your machine can be EXACTLY identified and we know what we're talking about. Thanks
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Coconut battery sais the battery is fine but when the AC charger is plugged in, it still says 'not charging'.
Can't tell the serial number right now because my macbook is at the macstore for a topcase replacement, but it's this one for sure:
http://www.everymac.com/systems/apple/ma...
의 답변
Apple MacBook "Core Duo" 1.83 13" Specs
Identifiers: MacBook - MA254LL/A - MacBook1,1 - A1181 - 2092
The 2.0 logic board should drop right in: MacBook Core Duo 2 GHz Logic Board
To go higher than that I would try to get an answer from Ben Eisenman with iFixit. I'll add a tag so maybe he'll spot this question.
의 답변
Allright, tnx alot! I'll wait for Ben's answer and in the meantime do some research of my own!
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
haes 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 895
