Why won't the hdmi inside of my xbox work
The hdmi output inside of my xbox one isn't working what should I do.
좋은 질문 입니까?
좋은 질문 입니까?
Try using another cable. Sometimes the cable can be at fault.
Make sure your TV or monitor is set to have HDMI as the input source. If your TV is set to "av" as a source the Xbox output will never show on the TV.
Does the port feel loose? When you insert the HDMI cable into the port on the Xbox, does it wobble a bit? If the port feels loose or wobbly, there is a good chance you will need to have it resoldered to the motherboard.
Good luck!
해당 답변은 도움이 되었습니까?
If your cable is working well. It is on your settings bro. If you are not sure about settings you can watch some reviews how to set it.
해당 답변은 도움이 되었습니까?
I know how t set it up it is the HDMI that's inside f my Xbox that doesn't work
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 142
