주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
Model A1288 / 8, 16, or 32 GB capacity
591 질문 전체 보기
Front Panel replaced, still no touch
I just replaced the front panel of my ipod touch (2nd gen). I still have no touch. I made sure that the ribbon cable was set and I'm not sure what to do at this point. What else could be causing the touch not to work?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
답변 1개
가장 유용한 답변
Here's the possible problems (in order of probability):
1) Make sure the connections are secure (perhaps try disconnecting and reconnecting)
2) It is REALLY easy to even minorly ripped the cable, or even bent it, it won't work.
3) The replacement might be faulty.
4) You might have the wrong generation/style of digitizer.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Due to the cheap-asss plastic tools (I purchased two sets because I knew they would break) the screen broke while trying to remove the front panel. So now I am out $75 for the front and $200 for the ipod. I should have never ordered the front panel from ifixit. I installed it correctly and it did not work, I doubt that I can get a refund now due to having to remove the panel.
의견 추가하세요
귀하의 답변을 추가하십시오
luke 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 834
