주요 콘텐츠로 건너뛰기
PowerMac G5는 Apple Corporation에서 2003년에 처음 제조한 데스크톱 컴퓨터입니다. 이 안내서는 2004년 Apple PowerMac G5 모델 번호 A1047 EMC 2061의 수리 과정을 검토합니다. 2006년에 먼저 개발자에게 그 후 소비자에게 Intel 스위치의 일환으로 판매가 중단되었습니다.
197 질문 전체 보기
Hard drives not coming out.
There are two hard drives in my power mac G5 but they won't come out the A drive I can pull out a little bit but gets stuck because there isn't enough room, and the B drive just won't budge a bit. I need to know which one to pull out first and how.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
person this from the manual:
Procedure
Release the drive locking latch by rotating it up.
Disconnect the drive data cable and power cable from the hard drive.
Pull the drive out of the drive bay, being careful not to touch the bottom of the drive.
Note: If you encounter resistance, use a flatblade screwdriver to release the latches on the drive bay rails as you pull the drive out of the bay. (See circled areas on the illustration below.) If two drives are installed, remove the bottom drive first.
Important: If the printed circuit board (PCB) is exposed on the bottom of the hard drive, hold the drive by its sides. To avoid damaging the replacement drive, take care not to touch the PCB during installation.
Replacement Note: If you are replacing a hard drive with a new drive, transfer the four guide screws from the sides of the original drive to the new drive. If you are installing an additional drive, transfer the guide screws from the side of the hard drive bay to the drive.
Replacement Note: When replacing the top drive, make sure the guide screws align with the middle slot of the drive bay, and then gently push the drive into the bay until it snaps into place.
When installing a bottom drive, align the guide screws with the bottom slot of the drive bay and slide the drive in until it snaps into place.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Perhaps use this guide for reference
Power Mac G5 Hard Drive Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
person 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 363
