주요 콘텐츠로 건너뛰기
Released Quarter 2, 2014. Identifiable by Model Number: HBS-750.
Why doesn’t my right earphone produce any sound?
My right earphone won’t produce any sort of sound. The model of my earphones is lg HBS-770
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
what are they connected to? PC, iPhone, etc?
iPhone and now the left side is having issues
댓글 달기
답변 1개
Start by trying them on a second device, to verify it is the item, and not the source that is causing the issue.
If it persists, you may have a connection failure between the reciever end, and the other side. in which case, you would need to check the continuities between the wire going from the reciever, to the failing headset. if it fails, replacing that wire fixes the issue.
or you can save your self 3 hours of labor in a specialized niche repair, and buy these.
https://www.amazon.com/LG-HBS-770-Wirele...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Preston Stepp 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 3,407
