Replaced the lower LCD and nothing!
I followed the instructions to replace the lower LCD display and put it back together. Now when I turn it on the LCD flickers quicklu and then nothing. It doesn't power up. Please help! what did I do wrong?
좋은 질문 입니까?
댓글 2개
kathy demerchant, when you replaced the LCD did you make sure all connections are seated right and are properly made? I would open it back up and verify all connections. Double, no triple, check your work. Sometimes it's the little things that matter. You had no trouble before you replaced the LCD?
oldturkey03 의
hi there, I took it apart again and double checked everything. It all looks good to me... The LCD screen was damaged before but the DSI still worked no problem. Now it wont even turn on. So I am wondering if I cold have possibly damaged soemthing while inside? Not usre what to do :(
kathy demerchant 의
