주요 콘텐츠로 건너뛰기
The LN46A530 has a 46" display, combined with SRS TruSurround XT. The PC input allows this display to double as a 46" computer monitor
70 질문 전체 보기
What to do about vertical lines ... already changed out t-con board
Hey I have replaced t-con board and ribbon, and still have coloured, vertical lines appearing on screen. What should I check next?
Also, any tests for that particular t-con board to verify it is not defective - tv model number is LN46A530P1FXZC.
Any help is much appreciated!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Check your ribbon cables going to the screen
댓글 달기
답변 3개
가장 유용한 답변
check the ribbons that go from the tcon to the lcd panel itself, to do that you will probably need to take the bezel off and rub you finger along the ribbons
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Dan does this mean taking the screen out partially
you shouldnt need to just the plastic bezel around the actual screen
댓글 달기
B P that will depend on what those lines look like. Post an image of what your screen displays with your question. Use this guide 기존 질문에 이미지 추가하기 for that. Besides the T-con board you can get lines from a bad main board as well as TAB failure. Tab failure is where the bonding of the ribbon cables from the driver board to the inside of the panel have failed.
Update (12/05/2017)
Looking at the image this does not appear a T-con board issue. Main board, possibly the panel driver or even the power board. Start by replacing the main board
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I agree.. this is what was meant in my post regarding the LCD screen may need to be replaced
댓글 달기
If the LCD is bad (could have caused T-Con to go out) there is not much you can do except replaced the LCD. A bad T-Con board usually shows as a blank screen with sound and some back lights. … A lcd with lines is usally the LCD screen it self. By looking and ready your post… I’d consider replacing the LCD.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
B P 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 64
전체 시간: 8,537
