MBP does not hibernate at low level but shuts down completely
Hi,
I ordered a non-OEM battery from iFixit (made by Simplo). After installing it, calibrating and SMC resetting my Mac keeps shutting down on low battery (mostly around 10%) instead going to Hibernation. Which is really frustrating for me as none of the work is saved.
Another thing is that the capacity keeps changing even after multiple calibrations.
After this, iFixit sent me a new battery but the problem is still there. Could this be that both batteries are faulty or is it my computer?
Can someone tell me what is the issue please?
Nam
Update (12/06/2017)
Dan:
Here you go. One more thing: When the computer shuts down and I plug the cord back, it shows 10% but when unplugged, it dies again. No way to get it on 0%.
Update (12/06/2017)
There it is. took me by surprise so this is the screenshot after plugging the cord back.
Update (12/09/2017)
Notice how the max capacity changes all the time.
Update (12/10/2017)
Hi everyone, well the problem fixed itself I guess. It took several calibrations but it should be ok now. The mac hibernates now, however the capacity of the battery shows 7985, although ifixit guarantees greater than 8250...
Update (12/13/2017)
Well it turns up that the problem is not solved at all. The battery keeps shutting down even though it hibernated last time. I’m going to return it.
Thanks for your effort.
좋은 질문 입니까?
댓글 9개
Can you install this gem of an app: CoconutBattery it should tell us what is happening here. Paste a screenshot of the main window in your question so we can see what it tells us.
Dan 의
OK, This looks good! Fully charged.
Run the system down (disconnect the MagSafe adapter) See what you can capture just before it shuts down if you miss it plug the charger in and quickly disconnect it then snap a screenshot again and post it in a new answer.
Dan 의
Did you make sure to fully charge and discharge the battery for it's first initial setup?
Anthony 의
Anthony - I do believe Do Hoai Nam did: "After installing it, calibrating and SMC resetting my Mac keeps shutting down on low battery"
Dan 의
Yep I did. Charged it, left it plugged in and used the computer until it shut itself down. Then i left it 5 hours and charged it to max and made a SMC reset. I’m at 25% now so I will soon be able to provide that pre-shutdown screenshot.
Do Hoai Nam 의
댓글 4개 더보기
