이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개
Brian O'Dell since you are saying to front not working, I am making the assumption that the rear blinkers are working. Check to make sure you have teh right bulbs in the front blinkers first, than check the wiring. The relay used is for the front and rear so that should not be the issue
댓글 1개
oldturkey03 의
