2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1390 질문 전체 보기
Refurbished Apple Screen or manufactured to OEM quality screen?
I was wondering as to which screen I should use. One option is with a reputable company offering a replacement iPhone 6 plus screen with 12 months warranty which they state has been manufactured to OEM standards, with the description quoting:
"Quality
This configuration of the LCD assembly is not manufactured by Apple or one of its licensed vendors, it is however the very best quality of the many after-market screens available.
This screen is Apple quality, it has the same Retina resolution, sensitive touch and anti scratch coating found on the Apple LCD's - its built to last and comes with our great 12 month warranty."
Specifications:
Manufacturer:
LCD screen: OEM
Digitizer, glass and frame: After-market made to Apple specifications
Please note: To protect our suppliers source of Apple replacement parts we do obscure the serial numbers on the product, this doesn't effect your warranty with us and doesn't effect the cosmetics of the fitted part
Part Origin - Aftermarket (compatible part) | This part had been manufactured from partially or completely all after-market components, this simply means that the part has not been assembled by the OEM or licensed factory. It is a compatible part made to original specifications and designed to be a like for like replacement for the original component. Here at The Replace Base Ltd we have very strict quality checks to ensure we only source the best after-market replacement parts, all parts are also covered under our great returns policy and warranty
Whereas another option is to buy a screen that is an apple original (apple logos present etc) with a one month guarantee but it has been refurbished by an independent company reselling the screens. Which one should I go for and would there be a difference? Additionally are there any drawbacks as I have heard some aftermarket screens affect the battery? And what would you recommend to go for?
There are various opinions regarding the screens, so I look forward to people's responses.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
Did you buy it from TheReplacementBase, in U.K.? I'm about to buy a new screen too and your experience made me quite optimistic!
의 답변
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
2개의 답변
선택된 해법
try looking at it this way.
The 12 month warranty means you have a good screen for 12 months no mattery what,
whereas the 1 month warranty means you have a good screen for 1 month, no matter what.
(Assuming you dont smash the screen)
personally, the apple logos, are just logos. there is no real necessity to use the apple items. our shop uses the new parts made to OEM standards so that we can transfer that warranty to our clients.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
Thanks for the answer. I do recall having fitting an aftermarket iPhone 5S screen which had a yellow tint, although this wasnt claimed to be oem quality. Do you usually see a difference between the original screen and the screens made to OEM standards? I have the screen ordered but will check it first so I can decide if I want to fit it or return it.
의 답변
the yellow tint on a non OEM is the type of LED they use. there are three different types of white LEDs. The Least expensive of them is the one used for everyday lighting, which is known as "Warm White." Warm White has a yellow tint on it.
The most expensive, is "Flat White" which has no colour tint. which is what OEM standards use. I personally have a local supplier for my iPhone screens, so i do not get them from iFixit. however, i have not had a tinting or quality issue with these parts. my store is able to offer a Life time Warranty with 3rd Party OEM Standards.
의 답변
Thanks for the response, understand a lot more about the different types of screens now! The screen I ordered just came through the post which was manufactured to OEM standards, colours seem to be accurate and identical to the original, couldn't really spot a difference.
의 답변
glad to hear! enjoy your new screen
의 답변
What is the name of your store Scott?
의 답변
4에 댓글 더 나타내기
의견 추가하세요
You should goto Apple Store to replace your screen if you want to use the Touch ID.
Apple does not distribute it's spare parts and if the phones mother board detects that the screen is not of apple. Your touch ID (home button sensor) stops working.
해당 답변은 도움이 되었습니까?
점수 -1
댓글:
Hi,
I replaced my screen with the manufactured to OEM screen and the touch ID is still fully functional. The board would only be wanting to pair with the touch ID home button , nothing else in order for the touch ID functionality to work. So using a different screen would not have an effect on the touch ID, only the repairer would be at fault if the touch ID no longer functioned after the repair. Hope this clarifies your statement.
의 답변
Hello Prince,
This is incorrect. While the Home button does plug into a cable which runs either behind the LCD, or through the LCD in some iPhone models, having an aftermarket LCD will not affect whether or not the Touch ID functions. Think of the home button connector on an iPhone screen as just an extension cord. It is basically a "dumb wire" and only carries power and signal to the motherboard. Now an extension cord can be broken. It is always possible to get a defective screen which does not support Touch ID but only because of damage to the part during manufacturing. I have had aftermarket screens and refurbished OEM screens with this issue. However, as long as your test checklist includes trying the fingerprint function on any phone, this will not slip you up.
의 답변
the board is paired with the home button, not the screen. please do not be dissuaded by this. if you damage the home button, then yes, it will cause issues. but the screen replacement, as long as you are half decent at repairs, will not cause an issue
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Suleman Sarwar 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 41
지난 7일: 142
지난 30일: 594
전체 시간: 8,848
