주요 콘텐츠로 건너뛰기
This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
25 질문 전체 보기
ASUS Memo Pad 7 won't charge
I currently have an Asus Memo Pad 7 that won't charge. I've tried replacing the cord and that doesn't do anything. At one point the tablet finally came back on for about a second and showed the empty battery icon then shut off. I'm thinking that it may be the battery and that I'll need a new one. Any thoughts on how to fix it? Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
If you can, take out the battery, then plug in your charger.
I could be wrong but that will directly power the tablet, then it should come on.
If it works, then its a battery problem, if it doesn't work, it could still be a battery problem as Im not sure if that will work.
You most likely just need to buy a replacement battery for the tablet!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Have you tried jumping it with a power supply?? or what volts is the battery reading when you test the leads?
If the battery is reading zero you may need to jump it then check the voltage again.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Peyton 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 11
전체 시간: 973
