주요 콘텐츠로 건너뛰기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 Touch Bar가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
260 질문 전체 보기
No battery status on menubar, current battery charge : 0%
I left my Macbook off for 10 days to repair my LCD screen, and when I boot up using the official charger, my macbook doesn't display the battery status on menubar, and my mac seems to be eternally at 0%, and I can't use my mac without being plugged in to my electrical outlet. I can't even turn the "show battery status on menubar".
I've tried to restart my SMC, but alas no luck for me so far.
See I broke my screen. Cracks on the lower right side, what should I buy?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 3개:
Can you tell us a bit more here on what happened with your screen. From the sounds of it the battery may have been damaged or the charging logic.
@danj Or maybe the repair person forgot to connect it properly?
I’m having the same issue and there was no damage to the screen.
When I click “show battery status in menu bar” it immediately unchecked the box and continues to not show battery status in the toolbar.
The battery has been replaced and is correctly installed as well as all dust and debris has been removed but the power source cannot be disconnected or it shuts down.
This was a sudden issue.
댓글 달기
답변 2개
I always make this mistake when working on my macbook:
Remember to plug in the battery! I always forget. gives me a good scare when suddenly my mac will not boot. the I remember. Oh yeah! the battery connector!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I will note, that I just preformed this repair, and had the same issue. My problem was that the batter was about halfway plugged in. I felt the click, but it still wasn't fully engaged. I blame the sticker for obstructing the actual connector.
댓글 달기
@afifyogapr if you replaced the mobo and have the old one I’m interested in buying it.
thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Afif Yoga Pradana 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 5,373
