주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2682 질문 전체 보기
Battery doesn’t hold the charge for long
Thank you already if you’re reading this
So I’m facing another problem with my iPhone 6s
After iOS update my battery won’t last more than 2 hours stand by or on screen use
I have already changed 2 batteries in 10 days thinking of the first battery was defective but i guess not
I have friends whose 6s working fine after the update but not sure what’s wrong with my iPhone 6s
I took my phone to nearest technician, he said that he will have to look into the logic board for some IC or something
Not sure what to do,
I have even tried restoring using all possible method ( DFU & iTunes restore )
The doubt I’m having is wether the problem is with the lastes iOS firmware or there’s something wrong with the logic board
One more thing if that helps
My phone is charging faster than usual and drains accordingly
Battery cycle is good, charges percentage by percentage no jump at all
Battery wear level is at 0% ( battery life app )
Pls help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개:
@aman did you ever get resolution on this issue? Just in the past 3-4 days, I'm having the same issue.
댓글 달기
답변 2개
Well apple said that they are releasing a new update that will fix that the software that made got messed up after released and I’ve had the same issue with multiples so all I can say is wait but till the new update then the new battery will keep your phone charged all the time!
If you have any questions or concerns please comment below! Thank you
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I’m already updated to 11.2.1, not sure how long i have to wait
The next update will be in about a month or two but it will 11.2.2 so it will quit then.
댓글 달기
The charger is probably broken and most likely to bring to store for new one
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have 3 iPhone chargers tried all three but no luck
댓글 달기
귀하의 답변을 추가하세요
Aman chadha 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 7,904
