주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 (Turbo Boost 최대 3.7GHz) GHz 쿼드-코어 Intel Core i7 프로세서.
465 질문 전체 보기
MB Pro Retina mid 2014 LogicBoard Replace
I have a 15" mid 2014 MacBook Pro retina (11,2).
I was wondering if it would be possible to swap out the logic board to logic board 11,3.
I see the only difference is the processor speed, but I don't know if this works with all components of 11,2 version, and I see the 11,3 version is a little bit less expensive.
My Problem: Constant shutdown in MB Pro Retina 11,2.
Thank you for your help!
Update (12/21/2017)
Hi Dan! look...
TG Pro Log 2.csv
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Shutdown types of issues often caused by a bad heatsink. Basically the liquid within it leaks out so its not very effective.
Download a good thermal monitoring app like TG Pro you'll need to full version here. The app has logging so you can catch the temps just at the point of shutdown. Lets see what it finds. Post the log file and a screen capture of the main window of the App so we can see it as well.
If thats it its a lot cheaper to replace the heatsink than trying to replace the whole logic board.
Update (12/22/2017)
To create log you need to enable it and place a location folder. As an example I have mine in my documents folder:
해당 답변은 도움이 되었습니까?
점수 1
댓글 7개:
I can't attach the log file (TG Pro)...
Sure, but how *.log files...
See Update and then just past the CSV file here
Dan thank you, but I know how to create a LOG file, my problem is how to attach the file for send you.... I try putting here but doesn't work...
댓글 2개 더보기
댓글 달기
귀하의 답변을 추가하세요
jrm 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 201
