주요 콘텐츠로 건너뛰기
A1708 / EMC 2978 — 2016년 10월 출시, 이 기본 레벨 MacBook Pro는 (OLED Touch Bar가 아닌) 기존의 function keys를 유지합니다. Function Keys 버전은 Intel Core i5 및 Thunderbolt 3 포트 2 개를 포함합니다.
Display switches off when opened more than 45 degrees
Hi
I have a late 2016 13.3" MBP with function keys. Lately, I've been facing an issue where the screen will go black(dim) when its titled more than 45 degrees. It's out of warranty as well
I am still able to make out the contents on the display using a flashlight. Went to the Apple Store, they want to replace the entire display assembly and are asking for $650 dollars for the same
Is there any fix for this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
We don't have any guides yet on the new 2016/17 MacBook Pro's. But the teardown can give us a clue on whats happening MacBook Pro 13" Function Keys Late 2016 분해도. If we jump down to Step19 we can see how this series inter-connects the display and the logic board. One of these ribbon cables is likely damaged in some way.
Carefully pop off your bottom cover and do an inspection of the connectors do you see any staining from liquid damage? Do you see any distorted parts or missing screws? Take some images so we can see if you see anything.
Most of us tech's haven't seen them yet as most issues are still covered under warranty. Do be careful as this still maybe covered under an extended warranty issue (defective part type of issue) so you don't want to mark your system that you've been in it.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I haven't yet collected the laptop from the diagnostics. Will try and attempt to check once I get it back
댓글 달기
답변을 추가하세요
Saurabh Jain 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 5,181
