메인 컨텐츠로 가기
Repair guides and support for televisions manufactured by Sony.
382 질문 전체 보기
No Picture. Sound, Backlight, Green LED is On. KDL-48W590B Year 2014
Which board controls my video display?
Opening the back panel I have a:
  • Main Board
  • TUS Board
  • LDHM Board
The TV internals look exactly as this YouTube video.
https://www.youtube.com/watch?v=zqDEoDZq...
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글:
Replaced the main board today to find the same issue as before
의 답변
I have the same problem. Replaced both the main and tus boards...no change. Just ordered a new ldhm board. Hoping that will be the fix.
의 답변
코멘트 추가
안드로이드 수리 키트
새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
지금 장보기
안드로이드 수리 키트
지금 장보기
2개의 답변
Did some looking around, and the problem may be being caused by your Main board.
이 답글이 도움이 되었나요?
점수 0
댓글:
Thanks for the reply. I saw a very vague troubleshooting chart pointing to the main board as the faulty video/picture. It does look like the HDMI inputs are attached to the main board. All older Sony Bravia’s say the TCON is responsible for a faulty picture. I can’t tell if this 2014 model is equipped with a TCON board.
의 답변
의 답변
코멘트 추가
Teerev that is why it is important to post images of your TV. That way we can see what you see and we can always help with the identification of boards , parts etc. Remove the back of your set and take some pictures of the layout as well as the different boards. Use this guide https://www.ifixit.com/Guide/Adding+imag... that. It will allow us to see what you see. Then start by using a Triage method, determine which could be primary cause and which could be secondary. Something like this
after that proceed with a general approach to the troubleshooting of No Video like this
The rest will then depend on your findings. BTW your set has a T-con board and I do believe it is actually behind your BAXL board (for now my money is on a bad T-con board ;-)
이 답글이 도움이 되었나요?
점수 0
코멘트 추가
답변 추가
TeeRev 이(가) 영원히 고마워 할 것입니다.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 30
All Time: 1,389
