주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
6MB 공유 L3 캐시 2.3GHz, 2.6GHz, 또는 2.7GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.7GHz).
Determining what to replace when USB port doesn't work.
The USB 3.0 port on the right side of this unit doesn't appear to be working. Plugged a Logitech Unifying transitter, which was not recognized. Tried a USB external Hard Drive to no avail. Same with two different external USB DVD drives. All of these devices work on the USB port off the left side of the unit. I dont think there is any power. I tried reseting the SMC and NVRAM, but those fixes didn't work. For the moment, we are using a USB port expander on the working USB port.
Nothing unusual with the unit. No spills or drops. Just sits on a desk and has been a very reliable unit. We replaced the Lithium battery and one fan a while back. It's worked fairly flawlessly.
Basic question: What's the best way to determine what needs replacing? I looked at the I/O board fix, which suggests two cables and a small I/O board. Unclear if I need all of them.
Is it possible there is something more simple that can be done?
I don't want to spend a lot of money if I don't have to.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Look closely at the cable connector with a loop glass or magnifying glass for burnt spots. If you find any burnt spots or broken connectors then you can replace the ribbon cable. If not I would go ahead and replace the ribbon cable and the usb board.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
David C Black 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 4
전체 시간: 130
