주요 콘텐츠로 건너뛰기
This is a stainless steel, 4 slice toaster oven. The model number is located on the bottom of the device. It has a single rack height and a removable crumb tray.
10 질문 전체 보기
Why is my ON light always on even if all the knobs are off?
My toaster is brand new and i used only once. The second time, the ON light kept turned on even though the oven was off. Is there anything I can do to turn it off?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi @csiqueirab ,
Don't know your toaster but was wondering if the timer control knob should be at the red arrow position and not at the blue arrow position as shown in the image below. Apologies if you have it already there
(click on image to enlarge for better viewing).
If this is incorrect, I suggest that you contact Black & Decker customer support either for an answer to your problem or if the toaster is faulty what to do to get a manufacturer's warranty repair or replacement.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
It worked! I can't believe I didn't see this feature "always on"! It worked! Thank you very much!
댓글 달기
귀하의 답변을 추가하세요
Camila Siqueira-Boonstra 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 162
