My gaming computer was used to be high graphics
My gaming computer used to have amazing graphics than suddenly my graphics started lagging then I changed it to Medium graphics it was still lagging then low it stop lagging. Please help
좋은 질문 입니까?
좋은 질문 입니까?
Do you have your hdmi/vga whatever plugged into the graphics card output or integrated cpu graphics? There will be 2 sets of output ports on the back of your PC, the graphics card set is usually the lower one but it depends.
EDIT: Also check task manager to see if anything is going on in the background eating up system resources. It could be a windows update slowing you down.
해당 답변은 도움이 되었습니까?
That work but I have a question for you.
But the but when I using the app it shows it and need to do it every time. There is a way to rid of them automatically?
https://lifehacker.com/pause-windows-10-...
You will need to just wait and let the update run at some point though.
It can go down hill over time as heat build up on the gpu. I would clean the cooling system and if that dosent help and the temperature dosen't go down then a operating system reinstall may be in order.
해당 답변은 도움이 되었습니까?
I did check but wasn’t problem . But thanks
Is this the same game? If not, then you need to upgrade. Of course, suppose a PC is not taken care of properly and cleaned from time to time. In that case, large quantities of dust could cause the hardware to overheat and throttle, but if it's outdated, all you can do is upgrade. It is straightforward to do if you have general knowledge about how computers are built; if not, a Youtube tutorial should solve that for you. The trick is to buy a good motherboard that will allow you to upgrade in the future and make sure that the components are compatible.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 114
댓글 1개
What are your PC specs, and what game are you trying to play?
Max Baron 의
