메인 콘텐츠로 스킵하기
Samsung Galaxy J7 기기 페이지입니다. 기기에 제공되는 OS는 Android OS v5.1입니다.
115 질문 전체 보기
Ive dropped my phone in water, everything works but the on/off button
I dropped my phone in water and immediately took steps to dry it, after a small amount of time, I powered it back on and everything seemed to work except the power button. I can still turn it on because of the home button but it only turns off on time-out. Looking for a solution to this problem. Any help is appreciated.
Thank You
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
3개의 답변
가장 유용한 답변
redbubba02 besides the great answer by @j0vian I suggest that first you do not turn on your phone, charge it or try to connect it in any way. Remove the battery from the phone to minimize further damage. After that completely disassemble your phone by using these guides. Using 90%+ isopropyl alcohol, clean your phone by following this guide. It was written for an iPhone but all the points still apply to your phone as well. While cleaning, check for obvious missing or damaged components. you can always post some images of your boards etc. with your question so we can see what you see. Use this guide Adding images to an existing question for that. Once it is properly cleaned, replace the battery and reassemble your phone. Only after it has been fully cleaned can you properly troubleshoot. Liquid damage is the hardest to troubleshoot and the most difficult to repair since virtually any part/ component may be involved. Your could simply be a shortened power button but it could as well be a failed component on the power circuit.
iPhone 이미지
안내서
Repairing iPhone Liquid Damage
난이도:
어려움
1 - 2 hours
iFixit 이미지
안내서
난이도:
아주 쉬움
2 - 5 minutes
해당 답변은 도움이 되었습니까?
점수 3
댓글:
@oldturkey03 ahh shucks.... thanks and have a happy new year and quit playing on the computer. :-) You should be having fun...
의 답변
@j0vian you are right brother. Wishing you and yours a Happy New Year!
의 답변
의견 추가하세요
The steps to a water damaged device it to fully disassemble it and clean the board with 92% rubbing alcohol and a toothbrush. if the device is powered on before all moisture has been removed then parts may have to be replaced. But the funny thing with liquid damage is that it can do very funny things afterwards if not immediately then later on.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
Everytime I tried to turn my phone off it not working
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
redbubba02 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 39
전체 시간: 477
