Why is my camera won't turn on?
This happened suddenly, there was no water damage or shock damage. I have 2 batteries, last time i've fully charged it and now it won't turn on IF the cable charger doesn't attached. It will normally works when the cable is attached, the camera would turn on and works fine and the battery indicator shows it fully charged, but doesnt charge at all, and when i unplugged the cable it will shut off immediately. Same thing if i plugged the cable, it won't charge at all even if i didn't turn on the camera, it just went blank. I've tried both of the batteries and it happened the same. Does anyone knows what is going on with my camera?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
I have a similar problem with the added feature of the LED light on the flash blinks intermittently. The battery is definitely charged and the inside doesn't show any issues with the connector plates (corrosion etc) from what I can see peering into the battery slot. I'd love to try a hard reset if it existed, but from what I can read I need to be able to access the menu which is hard to do with no ability to power on! Anyway, any ideas are appreciated.
의 답변
I have a similar problem with the battery.
Any ideas are appreciated !
The camera seems to not recognize the battery .... sometimes .. let me explain.
If the battery has been in the camera for awhile, many times it won't turn back on.
If i take the battery out, and put it back in, it turns on.
This is obviously not possible if it is in the underwater case and i am diving! Very frustrating ! i prepare the camera before diving, and by the time i get in the water, it won't turn on.
Any easy suggestions as to what i might try. i am on an extended diving adventure for 2 months in SE Asia with no access to an Olympus repair center.
Thanks for any ideas !
Donna
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
3개의 답변
선택된 해법
Hi @haikalrinaldi ,
It seems as though there is a charging/ battery power supply issue with the camera.
As it is a fairly new camera and as there is a 1 year manufacturer's warranty on it, I suggest that you first verify the purchase date of the camera. Then if it is still within the warranty period, consult the warranty statement in the documentation that came with the camera (usually it is found in the User Guide) as to what you have to do to make a claim for a manufacturer's warranty repair or replacement.
Opening the camera up to try and locate the problem, beyond what the user is allowed to normally do when operating the camera will void the warranty
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
가장 유용한 답변
I had the same problem, but for me it turned out to be the battery turned the wrong way. In most cameras it’s not possible, but in the the tg5 it is.
I hope it helps someone!
Marten
해당 답변은 도움이 되었습니까?
점수 3
댓글:
Mark, your suggestion just got my camera back in action! I had mistakenly put the battery back in the wrong direction and couldn’t figure out why it was not working. So glad I checked this site!
의 답변
Thanks so much. It fixed the problem.
의 답변
의견 추가하세요
Stylus TG-860 has same issue. Battery can be put in backwards, then it doesn’t turn on. Put it in the right way, and it comes on fine.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Haikal Adlan Rinaldi 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 10
지난 7일: 64
지난 30일: 234
전체 시간: 2,608
