I spilt tea on the back of my MacBook
I spilt a very little amount of tea on the back of my macbook
I heared a noise of electricity and it went off,
Now the macbook dont start at all
좋은 질문 입니까?
좋은 질문 입니까?
STOP! disconnect the MagSafe and open your system up following this guide: MacBook Pro 15" Unibody Mid 2012 Logic Board Replacement. Follow the first three Steps. Then jump down to Step24 using the image as a reference do you see any burn't components? Do you see any tea stains?
Your tea has shorted out some of the components we need to figure out whats damaged. If you think this is to much for you you'll need to find someone to fix your system.
해당 답변은 도움이 되었습니까?
I disconnected it but I can’t do this steps
and i want to know what this battery indicator means? And if the macbook is going to work again or it is dead forever?
You'll need to get your system to someone who can repair it. Time is your enemy here! The tea has acids which left on the logic board will damage it. Which is why we need to clean it off ASAP!
What does the battery tester telling you? The batteries charge state. At this point I would disconnect the battery internally! You really don't want the power to be running until you've fixed the system.
Can your system be saved? Hopefully! Without seeing the system I can't tell you how bad it is.
The tea probably damaged the logic board. You will want t open the device and look for any visible signs of liquid on the board. You can try to clean it off with IPA (>90%) and a soft brush. However, it may have shorted some components in which case this will have to be looked at by a repair shop that does micro-soldering repairs.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 44
