2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4680 질문 전체 보기
My iPhone is completely dead and will not start up or charge up HELP!
My iphone 6 charged like always at night but when I woke up one morning it was completely dead. I tried to charge it while I was in school but still unsuccessfully. It does not even show the charging icon when it is dead. Tried here after cleaning the charger with a small plastic tube. I got it well cleaned but it still did not work.
I hope there's someone who knows what's wrong and can help me :)
Sorry for my bad english. I'm just a child who does not know how to get my iphone to work again :)
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글:
I have this same problem My iphone 6 is usually charging at night but I fell asleep with it and this morning it was completely dark and it didn't show the charging icon or the apple logo and I did try like 4 different chargers and still nothing.
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
3개의 답변
가장 유용한 답변
Take it to the apple store, and they will check it for free.
They just lowered the battery replacement price $29.
해당 답변은 도움이 되었습니까?
점수 6
의견 추가하세요
Sorry for the late response, but this answer may help other folks. Before going to the Apple Store with your iPhone 6, 7, or 8, try doing a Hard Reset. Press and hold the top Power button and Home button at the same time until the Apple logo appears (about 10 seconds). This should restart your phone and clear any software problems. This is the first thing that the Apple techs will do. If this doesn’t work, then go to the Apple Store. Good luck
해당 답변은 도움이 되었습니까?
점수 3
댓글:
But what if your apple iphone6 is completely dead and when you put it on the charger it shows that its charging. but just wont turn on completely
의 답변
It worked, you saved me a trip to The Apple store, thank you so much!
의 답변
I didn't work for me.
의 답변
의견 추가하세요
Sounds like the battery or lighting connector assembly went bad. More than likely it was your battery. Try the apple store first. If it's the lighting connector assembly you can change yourself. iPhone 6 Lightning Connector Assembly Replacement Here's the guide. It's not bad to change out, just follow the guide. Hope that helps.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Elias Månsson 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 47
지난 7일: 350
지난 30일: 1,563
전체 시간: 23,316
