주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2686 질문 전체 보기
iPhone 6s Touch ID working, normal home button is not
Dear Geeks,
I have done a few repairs back in the day, but im not totally up to date right now. However, I did some research but cannot find an answer for my iPhone. So here is the question.
I accedetially dropped a few water drops around the home button of my 6s. I already replaced the screen before, so its not water resistant anymore. After that, the normal 'go to home' function of the iphone did not work anymore. The touch ID works perfectly though. I have red somethings about splitting the home button on a 6 model, but I am working with an 6s. So now; can I fix the homebutton and keep the touch ID?
Kind Regards,
Badslipper (NL)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Dear Minho,
Thanks for your answer. I understand what you're saying but what is IPA 90%? I guess its not Indian Pale Ale as I know that as an IPA :) Hope to hear from you soon.
Kind Regards
댓글 달기
답변 1개
선택된 답변
If you're lucky, only a small amount of water got in and it stayed localized around the HB. Open up your phone and inspect the inside to see if the Water Indicator stickers are red.
Also check to see if there is any water residue or corrosion around the HB area. There might be a bit of corrosion that is impeding the actuator. You can try to clean it with IPA (>90%). Unfortunately, you cannot replace the HB and retain the Touch ID functionality. If that is important to you, you need to go to Apple for that service.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
IPA - Isopropyl Alcohol
When it's 70%, it's also refereed t as rubbing alcohol.
댓글 달기
귀하의 답변을 추가하세요
Guus 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,475
