주요 콘텐츠로 건너뛰기
모델 A1286. 2011년 2월 출시 / 2.0, 2.2, 또는 2.3 GHz 쿼드-코어 Intel Core i7 프로세서
583 질문 전체 보기
Replacement of Harddrive: SSD with SATA 3
Hey there,
I have read that the new OCZ Vertex3 SSD will have an SATA 3 6.0Gbit/s connection. Does the SATA controller of the new MacBook Pro series (8,1 8,2 8,3) supports SATA 3?
Thank you for your support!
Sebastian
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
This article should give you all the information you need on Macs and support for SATA 3, USB3, 6 gbps and SSD support: http://www.stationstops.com/2010/02/17/a...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I believe that the harddrive will work regardless if the SATA controller is SATA 3 or not, it just won't at its full speeds. That SSD will still provide a very nice performance boost though. SATA 3 is backwards compatible
Don't forget to mark whichever answer satisfies your question, if any.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Hi Skippy722,
Thank you for your reply.
The performance of a SSD drive with SATA 2 is quite nice. I have currently installed a Vertex2.
But I was wondering if I can reach the full speed of 550MB/s with a Vertex 3 SSD via SATA 3 in the new MacBook Pro.
Via SATA3, yes you will see full speeds, in a perfect world. There are other issues, so those numbers are just the absolute maximum that the drive can do.
댓글 달기
The article cited by mayer is about last year's notebooks. Apparently the HDD shows as SATA 3, but not the DVD drive (that may be a SW limitation; a similar situation happened with SATA 2)
http://forums.macrumors.com/showthread.p...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi,
My macbook late 2009 has sata-2 hard drive interface. I got a SSD SATA 3, Kingston Hyper SSD 120. Will it work if I connect the ssd sata3 with the sata2 connector inside my macbook?
Thanks
Adriel.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Sebastian 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 24,727
