Recovering data with broken system
Windows 8.1 won't boot on this device. I have some important files to recover from it. Bootable usb with linux doesn't help. Is there a way to get them back?
좋은 질문 입니까?
좋은 질문 입니까?
You can try using an external USB adapter for the drive and then connect it to a working computer to try to copy your data.
해당 답변은 도움이 되었습니까?
does it have hdd though?
HDD or SSD? both should work fine with a hard drive docking station. You can find them on amazon I'm sure, or just open up your desktop and connect with sata.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 376
댓글 6개
Do you have a working desktop PC? So you could test the disk.
ULEES 의
i have but im not sure if it has internal hdd
Tomasz Kowalski 의
How did it break? did you drop it? spill something on it?
Aiden 의
i installed updates and the system crashed
Tomasz Kowalski 의
Problem fixed: i booted the windows 8.1 usb drive, then launched cmd. Using it I managed to move all the files to the usb. However switching between the drives doesn't work without "cd /d c:\".
Tomasz Kowalski 의
댓글 1개 더보기
