2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
714 질문 전체 보기
Logic board get hot after I replaced the screen
Hey guys,
I have this issue today after I replace an iPhone 7 plus screen. Is not the first time for replacing the screen for the iPhone 7 Plus. After I replaced the screen is works fine but freeze on Apple logo and the logic board get really hot and is not booting to the system!
I tried every time and disconnected from the battery cable to turn off.
Any help guys?
Thank you
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
3개의 답변
가장 유용한 답변
It’s the display. iPhone 7 and up don’t have a physical home button so in the instance that you connect the flex cable that runs the home button you can run into this issue. Doesn’t happen all the time but with some after market displays the button isn’t coded properly. Meaning your phone just can’t process the fact that you have a home button and the software never loads.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Have you tried reconnecting the broken screen?
Do you have another screen to test it with?
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Yes sir I connected the old screen but it got the same issue. "stuck in Apple logo and the logic board get really hot.
When I see the logic board get really really hot I disconnect the battery cable, because I don't want to burn the phone. I'm trying to be really careful.
의 답변
When you replaced the screen originally, did you unplug the battery? I sounds like something is fried.
의 답변
Yes I unplug the battery after I replace it! but during the replacement I didn't turn off the phone as usual!
right now if i connect the screen and turn on the phone it will work but it will stuck on Apple logo, and Logic board get hot!
의 답변
try to connect the cable to itune and do DFU reset the phone and see if the phone reset it itself
의 답변
what about the heat on logic board! do you think i don't need to worry about it?
Is the heat from the logic bard not gonna cause any problem to the phone?
의 답변
2에 댓글 더 나타내기
의견 추가하세요
disconnect all the ribbons and just plug in the lcd connector and the battery and see if this lets the phone boot to the main screen, if not and the phone is still overheating try and locate where most of the heat is coming from
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Yes sir I already did and still get hot
the heat came from the Logic board
as you can see in the picture I marked in the red!
all the heat come from here when i boot up the phone, and the screen stuck on Apple logo and don't let me get in inside the iOS!
Picture:
http://fowzy.net/oboxQC5XMlghqA6I.jpeg
의 답변
if you keep the lcd disconnected and power on does it still get hot or just when the screen is plugged in
의 답변
Let me check @djdannyrock give me a moment please
의 답변
I’m having this same issue please help, yes if I unplug the lcd ribbon and leave battery ribbon connected it doesn’t get hot like it would with the lcd ribbon connected
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Fowzy Alsaud 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 11
지난 7일: 26
지난 30일: 82
전체 시간: 2,091
