주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2014년 4월 업데이트에는 참신한 듀얼-코어 i5 및 i7 프로세서와 더불어 배터리 성능을 약간 향상시켰습니다.
313 질문 전체 보기
Display doesn't work after replacement
My Macbook air display was broken and I bought a new display assembly.
I've replaced with the new one, but nothing is shown in display.
I realized that I connected the display ribbon cable( on the top left at the logic board ) as wrong side... ( top and bottom were changed... )
I changed it correctly and turn on the Macbook, but it does not show anything only black screen.
There is no light on the apple logo.
If I turn on, the fan rotates well.
I've checked the back light fuse on the logic board with my tester, but it is not a problem.
Are the GPU or Display Ribbon Connector or something wrong?
Do you know what I have to do in order that the display works or in order to diagnose?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Was the old screen functioning enough that you would be able to see anything? if you still have it try it see if you get anything. even if its cracked just to see if it works and rule out a damaged logic board etc.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
hottestchilipepper 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 43
