주요 콘텐츠로 건너뛰기
Fourth generation Honda Civic
33 질문 전체 보기
Headboard lights don't turn on.
When I turn on my car the headboard lights don't turn on i can't see my speedometer nothing. How do I fix it? Change Bulb? Fuse? HELP!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi,
Have you checked that the Panel Brightness Control Dial (or Dimmer switch as it is more commonly known) is turned up to maximum and that it has not be turned all the way down?
It is a bit hard to see in the image but it is on the dashboard to the left behind the steering wheel.
(click on image to enlarge for better viewing)
Are your tail lights working OK?
If they're also not working then check the fuse (in the fuse block under the dash) as the dashlight and the tail light share the same fuse.
If the tail lights work OK then this link may be of some help.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Christine Perez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 18
전체 시간: 457
