주요 콘텐츠로 건너뛰기
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 질문 전체 보기
Water doesn't come out of the steam wand or the group head.
Water doesn't come out of the steam wand or the group head. When I turn the machine on, the machine heats up and the pump can be heard. I know that water enters the boiler because it swishes around on the inside. I have not descaled it yet. Would descaling it do the trick?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
I would first make sure the steam wand tip isn't clogged, as that's the only thing that can prevent water from dispensing from the wand if the pump is indeed running and creating pressure. If you can't get any water to dispense you won't be able to descale the machine, as that requires getting the descaler inside the boiler. You may also want to try taking off the group head screen and removing the boiler valve retaining nut, spring and nipple; water should be able to flow from the boiler then. If not, it's possible the pump isn't working, despite making noise.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Michael M. 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 217
