주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone not powering on.
I've been dealing with iPhone repairs for a few years but this one stumps me. I have a iPhone 6 that was initially mine and passed down to a few siblings and had a few screen and battery replacements. But on the last battery replacement the battery seemed to act weird. Put old one in was fine but didn't hold charge as well. The phone ended up just up and dying. Wouldn't charge. So I got the new battery from warrenty and tried that. Still won't power on. Got a known good battery still won't power on. Had different sceen that was good still won't power on. Replaced charging port still won't power on. Tried hard reset and all still no life. How do I figure if the logic board is my last issue or is the main issue? That's the only thing I haven't had to replace on a iPhone. Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Can you check if the phone is detected via iTunes? It may be turning on with no backlight.
You can also check if the apple logo is appearing when turning on by putting a flashlight on the screen.
If it's a no backlight issue, it can only be fixed via microsoldering (replacing backlight filter / repair backlight circuit) which some mobile phone repair shops and etc offer this service.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
If it isn't the back light, the power management IC may be the most likely to blame. They are known to go bad in iPhone models as they age.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kaden Seidel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 426
