주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Replacement screen not sitting in on bottom right
This is probably a common issue for aftermarket screens.
Is there any particular reason why it happens? I tried two screens from different suppliers and the same issue occurs.
Also the iphone housing is in excellent condition, no bends or dints on frame.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
Hey, if you check the flex on the screen that goes to the motherboard, there is a metal part on it. that part probebly hits the motherboard or anything else nerby.
see this picture:
https://d3nevzfk7ii3be.cloudfront.net/ig...
the flex should lay as this one does a little bit from the metal part on its right side and not to high up.
I have had this problem twice before and that helped.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
thanks so much that worked, i had to flatten it out because that rectangular brick slides out of place and it fits in a small rectangular hole and if they dont match the corner comes up
댓글 달기
Hi Ben
You are one of the great sages, but if it were not so, I would say:
Something similar happened to me once. I would say it has to do with the fasteners in the frame of the screen or the thickness (too thick) of the frame.
I have also seen chassis bent in strange ways, it is not necessary a blow, with enough pressure can affect.
Another screen or reinforce the adhesive on that part could help.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi there is a possibility that your iPhone's rear housing is bent it's a very common issue with the iPhone after been dropped on the corner or kept in tight Jeans so it may never fit properly. you can check by placing it against a flat surface (making sure the camera is not in the way) and check if there is any gaps between the surface and the phone if there is you have a bend, sadly a rear housing is such a pain in the arse to replace even apple just replace the whole unit for exchange price which dose vary if you go to a Apple Sore or Apple reseller i would not trust a corner shop with this job.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ben 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,012
