주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Riding mower won't start
Hi, My Craftsman model 917.250, Kohler 26 horse won't start.
I hop on, depress brake, turn key, engine turns over.
It has good spark at spark plug - removed plug, reattached plug wire, turned engine over with end of plug held near metal frame, sparks.
Checked fuel, also squirted starter fluid in carburetor, turned engine over, still won't fire.
Squirted starter fluid directly in cylinder - removed plug, squirted fluid in cylinder, replaced plug, turned engine over, no fire.
Checked for damaged flywheel key, okay too.
Scratching my head, puzzled, any ideas?"
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개:
Scot Mckone if you have fuel and spark check your timing as well as your valves. You may not have compression
My craftsman riding lawn mower will not start wont even click on what could be the problem
My riding mower aslo wont fire done bought new plug new solenoid new fuse repaired wires also wont start only get a little click
댓글 달기
답변 1개
try to bypass the ignition switch by puling it and closing the circuit manually
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
If it is getting spark, how will over-riding ignition switch help?
It may not, but I like to remove as many things from the system as possible when troubleshooting.
The brake sensor may not be working too. It sound like you have been very thorough. Compression as mentioned by oldturkey may be your best bet.
Has compression. how do you check timing?
Scot, try using this previous thread as there seems to be a lot of similar issues...
Craftsman tractor engine compression or timing issue
댓글 달기
답변을 추가하세요
Scot Mckone 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 25
전체 시간: 7,286
