Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
131 질문 전체 보기
Will RAM from iMac A2210 work in A2111?
I have two iMacs, the newer one using 800mhz DDR2 RAM and the older using 667mhz DDR2 RAM. Having upgraded the newer one, I have 1x1gb chip left over that I'd like to put in the older imac, doubling it's memory capacity. It appears to be pin compatible .. will it work at the lower clock speed?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
If you're talking about EMC 2210 & EMC 2111
The EMC 2111 uses PC2-5300 667 MHz RAM
the EMC 2210 uses PC2-6400 800 MHz RAM
These are not interchangable. Mixing RAM is never a good idea. The 800 MHz may work in the older machine but will clock down. My experience with using faster RAM in slower machines has not been good, it will sometimes work but give lock ups. But I don't think it will hurt your machine either so give it a try and let us know.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
Kelley 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 595
