주요 콘텐츠로 건너뛰기
The HP LaserJet CM1415fnw is a multifunction color printer produced by Hewlett Packard.
19 질문 전체 보기
Always posting Misprint mess after the first page, then Cleaning mess
When I print it will stop after the second page and say “Misprint” then when I select continue it will print the last page that it printed and the next page.
It will then say Cleaning and then it will say misprint again and print the last page and the next page and so on and so on;
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Have you replaced the drum and toner?
You may need to give the printer a good clean.
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
I have the same problem, cleaned it with compressed air, changed the cartridges, but there doesnt seem to be a changeable drum
All Laser printers use a drum.
Do you have a Jet printer which uses liquid color cartridges?
Nope, it is the cm1415. There is no mention of a drum even in the servicemanual
The drum is part of each of the color cartridges.
Check the paper feed rollers. If you used a refilled cartridge it may be bad.
I have used original cartridges, imitation ones and originals at the moment. Unfortunately I tried to clean the pickup roller yesterday... With silicone spray..., yes not very smart haha, so I ordered a new set of rollers, including a transfer roller. Hope that will do the trick
댓글 달기
I think it might be an online anomaly, does the indicator light blink?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Try replacing or cleaning the pickup roller. There is a YouTube video that explains the procedure. I took mine out and cleaned it with a rough sponge and dish soap. Works great now.
Replace or Clean Pickup Roller on HP Pro CM1415fnw
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
jen cokoa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 18
전체 시간: 1,604
