주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4919 질문 전체 보기
Determining U2 or Tigris failure on an iPhone 6
Hello,
Just looking into an iPhone 6 and the device boots and behaves normally, it draws between 0.08mA and 0.50mA. It changes the battery icon when the cable is plugged in.
Tried 3 computers, 2 different cables and 2 connector ports - same results.
I would typically suspect U2 if it was drawing 0.00mA.
From reading, Tigris is the element that deals with USB communication.
The voltages around this area are ok, theres a 1.8V, VCC_Main, USB5V0. none of the caps around here read anything different when normal.
The USB connector on the board itself is physically clean enough.
Before going ahead with a U2 swap I am wanting to know is it best to swap Tigris first because to me this seems like the most likely culprit.
Thank you :)
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 해법
Although I doubted if the U2 was even the issue because power was getting inside the phone, replacing the Tristar IC did the trick. I usually like to refer to STS Telecom for this fault, they have a good video that I refer to if I need it:
https://www.youtube.com/watch?v=XLFkvPA_...
Problem fixed!
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Elliot 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 23
30일 전: 95
전체 시간: 2,753
