Disassembly and Repair Philips 37pfl9604h/12 Black and negative screen
Could someone help me with pictures of disassembly of the Philips 37pfl9604h/12. Also if you have to remove the footh first and how.
Problem is:
The screen is at the left side normal but on the right side slow, and negative, and black.
Questions:
How do i disassembly this tv
Could anyone tell me which part it could be? I heard already things like the ribbon cable, the TCon, or the AUO
Could anyone tell me where i can buy this parts, of let it repair if its too small work or soldering work?
Thanx in advance
I thought you have to take of the footh first to disassembly the tv, thats why i asked that, if it’s possibly without , then also good:-)
Hereby the pictures
좋은 질문 입니까?
댓글 1개
@ti080 I am a bit confused by your question. "to remove the footh first and how." referring to the stand? "The screen is at the left side normal but on the right side slow, and negative, and black." can you post some images of what that looks like with your question? That way we can see what you see. Use this guide 기존 질문에 이미지 추가하기 for that
Yes it could be all of the parts that you already listed but unless we can see it and you check a few things it is hard to determine.
oldturkey03 의
