주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Home Button Nowhere to connect to
So my Moms iPhone 6 had the problem that the Home Button sometimes didnt register when being pressed to finally to work anymore.
I ordered a new Home Button off Amazon and tried to replace it today, when i wanted to disconnect the old Home button from the flex cable i quickly realized that there was nowhere to connect the new one, i thought that i may ripped off the connector but that was also not the case.
Pictures : https://imgur.com/a/Ex6oz
Would i now need to also order a new Home Button Flex cable and replace that ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Its ripped.. the connectors on the flex are probably stuck in your mothers homebutton. You’ll need a new backplate.
iPhone 6 LCD Shield Plate with Sticker and Home Cable
iPhone 6 LCD Shield Plate with Sticker and Home Cable 이미지
상품
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
okay thanks for your help, is it also possible to just buy the flex cable and go with this tutorial : iPhone 6 Home Button Cable Replacement
or does the Sticker not stick as good anymore after opening it up ?
You could just order the flex cable, but I personally only orders the complete thing.
댓글 달기
귀하의 답변을 추가하세요
KekoMaster Atmisbir 2 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 61
