Why is my picture showing only in black and white
why is my picture showing only in black and white
좋은 질문 입니까?
좋은 질문 입니까?
Go to settings/general/accessibility/grayscale , turn off if it's on. Worked for me it got turned on doing one of my exploring moments.
해당 답변은 도움이 되었습니까?
Hey
Just wanted to thank you!
thank you !!! you are a life saver
This just happened to me. I was sitting across the room not near the remote on the phone and noticed the Bixby voice command listening randomly to my call trying to take instruction and giving me an error that it did not understand. Then it went grey.
Such a lifesaver! Worked flawless.
Same happened with me like what happened with heather stark.. it suddenly turned grey...while I was operating Bixby voice
Generally, if your TV picture is only in black and white, the cause is usually an incorrect/inadvertent connection to the TV from your video source.
Or, a loose connection can cause this also.
So, check those connections carefully.
Best wishes ;-)
해당 답변은 도움이 되었습니까?
Okay so this is just to clarify a few thins. always check your TV’s settings first. Make sure that it is not on some grayscale settings etc. After that check every input source to see if that makes a difference. Try HDMI, Component, COAX, and whatever input source your TV may have (also try different cables). If that checks out okay you will have to look behind the back cover. The most common cause for black and white is actually a failed Gamma IC on the T-con board.
해당 답변은 도움이 되었습니까?
Whats the gray scale call if u dont see it
Mine don't have a t-con board it just has power board and main board
@billy the T-con board could be part of the main board.
I do not have a general in my settings tab. And can not find grayscale anywhere. This has happened a few times. Always goes back to color on its own. This time it’s been a week and still black and white. Help please
@tonyaschlebach I would like to refer to my original answer on here. It sure sounds like that board. We would need to know what Make and exact model your TV is and if you are willing to "work" on it to make proper determination.
24 시간 전: 38
7일 전: 221
30일 전: 1,026
전체 시간: 90,366
댓글 13개
Try performing picture test go to menu- support then self diagnosis - picture test if the picture is colored there is nothing wrong with the tv its the connection that you have
Vanessa 의
no problem there checked connections they are good, still not showing color
charles turk 의
@charlestruk
What did you do in the end? I have the same problem
achikamdorani 의
HI
Thank You. I do appreciate your fix.
We have these Tvs in Hotel rooms. One of the room it happened second time. Do you know why would it do that? We do not have samsung remotes. We have third party programming box for Dish Network.
Thx
Sunny
Sunny Patel 의
achikamdorani it self corrected idk know why but the color just popped back.
charles turk 의
8 댓글 더보기
